Thanks Cab
I tried the new ones on with the v-spring on the head, just to see what would happen, and they "sunk" well below the retainer top surface. They are 7 degrees, single grove for an 11/32" stem.
I am now wondering if the explanation for this confusion is that the heads were bought through a reputable engine builder and they perhaps switched to 10 degree retainers since the heads were intended for a race motor. Any thoughts?
Ragnar in Iceland
66 Charger, 451, .582" lift, 11" conv. 4.10:1. 4118 lbs 11.75@117 mph on regular Firestone Firehawk radials. Icelandic Champion in MC 2007, 2008, 2009 and 2022.
