So no go for plan B? Haha
Thanks for the responses. I wish somebody knew more about that $100 hat if it is a tuning nightmare I will steer clear. Going as big and tall as possible totally makes sense. The paper filter should slow down any air flow enough to prevent a lot of turbulence above the vents and butterflies- as long as it’s a big enough ‘filtered plenum’ it won’t get ugly and windy in there in a bad way?
My third idea came from the dollar store and is not the best one but for $6 worth a try for ABA testing... WOOHOO !! that's mine ! ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
