The oil slinger does have purpose. Is it always needed? No. A timing gear or balancer with an imperfect surface or multiple timing key cuts at thier meeting point will leak through the keyway out of the balancer hub. Not so much a timing cover seal issue. Think of it as a combination seal umbrella/ banjo seal.
