If your sure you will always be happy with the results of the SB stroker then go for it
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
if not think twice about the future now
The reason I suggest that is you can't get much more C.I. out of the stock type 360 or 340 blocks, making a 400 block have 518. C.I. is easy
![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
I've made 514 HP on CA pump gas with a 418 C.I. 340 stroker motor with a set of mildly ported W2 race heads, I made 612 HP with a pump gas 400 stroker motor that was 511 C.I. with a set of OEM iron 906 heads that where mildly ported with larger valves by the same head porter in SO CA
![work work](/ubbthreads/images/graemlins/custom/work.gif)
You can make 2.0 HP per C.I. on both types motors, I built a B1 headed 544 C.I. motor that 920 HP on race gas in the Boise, ID area several years back with out a lot of effort on tuning it
You get to choose your type of motor
But I'm a BB guy
![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif)
