Thanks, I will keep this updated. The car is a 62 valiant, I plan on using the hemidenny front suspension/k member, I want to run the 8 speed automatic but I will most likley use the 904 in the car atleast to begin with. Rear end is an 8 1/4 from an unknown A-body. This motor should make 300 HP and save a couple hundred pounds over a small block.
