Originally Posted By fbs63
My personal opinion is the early 5.7 is the best choice for boost. Thick cylinder walls and a smaller bore. Better for complete ignition of the boosted mixture. Top Fuel motors are 4.310 x 4.500. There's a reason they run the small bore.
Before the BGE/Hellcat block, I would agree 100%, leave the 6.1s and SRT392 blocks to the NA crowd. Now A budget build lower RPM 400CI and under, your a head of the game if you use the older 5.7 block.....you have a better chance of liftting the heads before you hurt the older block...with good internals.
Higher RPM Short stroke build 380-410Ci the BGE would be a great block to use , look at the power the Hellcat/Demons are making.
3.9-4.00 inch bores are what a lot auto manufactures are using and have gone to , it's a better bore size to keep emissions down.
Interesting point about the Top Fuel , Bore/stroke ratio equals .957, Bore stroke ratio for the 5.7 based "392" 4.05 crank is .967 and 4.08 is .957, to get that with a stock 4.09 BGE/Hellcat you need a 4.25 crank(.962) need a 6 inch rod to get a 1.14(1.15 zero deck dry) Comp Ht, and 6.07 length rod gets you a 1.08ish..but both are horrible Rod ratios
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
