Originally Posted By PorkyPig
How would I be able to tell what the trans original application was? Is there something in the markings that would help identify one with 4 pinion planetaries instead of 3 pinion, for example, without having to tear into it first? confused
The part number stamped in the drivers side pan rail will tell the application, post the numbers here.
Since most 727's are 40+ years old, it's anybody's guess what you'll find inside.
The INTERNET, the MISinformation superhighway
