I will check with Dove as well. someone at Indy said if I went with the Jezel set I don't have to change my push rods. is that a true statement? wouldn't a offset 1.6 rocker for a 360-1 set up be the same across manufactures, after all they are adjustable.
I may not understand what would be different.
Thank you
Kiddart
