Originally Posted By 72roadrunnergtx
There won’t be an adjustment hole on a six-pack (2300 center carb?) divorced choke spring assembly. If it is adjustable, it will require removing the spring assembly from the manifold. Not all versions of that choke spring are designed to be adjustable, some are fixed.
Some related six-pack choke info here
Yes that's how mine is. Looks to be adjustable. Problem is one of the bolts for the choke spring assembly broke off and I need to remove the center carb to get to it. I can't for the life of me get the fuel lines apart. Any tips?
1970 EK2 T/A 727
