Originally Posted By poorboy
It sounds like its time to fix the broken motor/trans mounts, or fix the broken slap stick mechanism, I suppose an adjustment might help if the problem was 1-2 and maybe 2-3, but going from 1-2 and then 2-3 is pretty unusual.
Those are the only 3 reasons I ever ran across for a Slap Stick not to function correctly. Gene
I agree with this. Check your mounts.
