when you say no vac can for mechanical advace does that mean you have a leanburn IGN system with a stock dist/no vac can????
or does it have one and not hooked up? add a vac source to see if it advance any?
no vac leaks found correct?
sure sounds like throttle blades on trans slots like most holleys when acting this way.
