I don't know if this will help but if you go to rockauto.com and look up the hose you need you will see pictures of the hoses available from various manufacturers. You can also get the part numbers. I think the NAPA website also includes pictures of the parts. I had problems finding the correct molded hose for my Dodge truck. The ones the parts stores had were not correct. Then I figured out my truck had a radiator with the top hose fitting in the wrong location.
