Originally Posted By Thumperdart
Too add to this, a too small of a carb on a hot motor can be real sensitive and a bear to tune sometimes because of the high velocity however I have Dommy's on cars/trucks that the "pros" said would never work for the reasons you mentioned above as in not enuff velocity..........I've had 1250 Dommy's on my dart for street testing with good results and why is that............ work
i'd say your keeping the rpm up.
