1.5 times the diameter or 8 threads will usually give you full strength. In aluminum engineers sometimes go 2x the diameter.
If its 1.5 times then why do they say at least the stud dia on wheel studs has to be sticking past..thats why I said at least the dia.. I never heard that 1.5 times even in the fastners lab
