This will be going into a 1966 Plymouth Fury C-Body. Not sure if a B-Body hemi type oil pan will fit? On my other engines I did the 1/2" pickup modification, but had problems finding oil pan pickups. On the Charger with the BCR girdle, I ended up making my own oil pickup tube to fit the low profile Milodon oil pan.
I did find some links to the old posts using a Google search.
