Whatever you use, remember that the battery cannot be secured to a mount that is not considered part of the frame or properly secured to the frame. Minimum of 2 3/8" fasteners to secure the battery. Can't just stick a box in there with some screws, sit the battery in it and call it a day.
If the results don't match the theory, change the theory.
