My Megasquirt system has an option to PMW fuel pump based on pressure readings(2 sensors) but the learning curve looks much steeper than the benefit.
I have seen others have good results by isolating fuel system components from heat sources with fiber washers etc, they have had more of a benefit this way than by using a pump controller. Some claim the pump controller makes things worse?
68 Barracuda Formula S 340
