Typically, the “correct” oil feed location for a bb Mopar is having them parallel to the axles, and above the band.
Hopefully the place that installed the bushings didn’t put “giant” holes in the bushings.
A .030 feed hole is more than enough.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123
Dealer for Comp Cams/Indy Heads
