A friend of mine is having problems clearing the front of the K member on his 73 Charger with aftermarket oil pans. He's tried 2. The last one the sump clears but the front hits before the motor reaches the mounts. Looks like 440 source, milodon, etc list the same pan for 66 up. Is there a specific pan for the later rubber mounted K member? Thanks!
