you have to figure out where you can hang the turbo to get the piping to and fro and then start by making at least a temp mount to put it there. Cardboard and pvc can be your friend in the early stages. The next one I build I'll have a vertical band saw (even just a cheap harbor freight one) and a bench sander to clean up the angles. Sawsall with hose clamps as cutting guides was still pretty difficult to do well for me.
70 Sport Fury
68 Charger
69 Coronet
72 RR
