Us limp wrists must sit behind desks and earn enough money to afford OD
If you have a small block that swap to a 518 only set me back $1,000 using the factory TC that came with it. Looking at $1500 or about if you need an Ultrabell to fit it to a big block. As long as you can make your own mount - no problem.
