I used to be able to do it on the floor,but when the age catches up the mind says yes,,,and the body says NO.That being said I used the floor jack till I bought the M/C jack.Either way I had to tilt the tail up to clear the bellhousing to get it out fromunder and twist the trans to clear the headers.Just need to be carfull with the trans getting on & off the jack you're using.
HEMI-ITIS has no cure. My condition is fully BLOWN!!
