That truck looks a whole lot better then the last 2 I drug home! Did you get a title with it?
The one I'm building will be built without fenders because the fenders I have will take around 20 hours each (I'm a welder by trade) to make them usable, then they will need body work to be pretty. My truck is on a Dakota chassis, with an EFI 5.9 Magnum (360) and its computer controlled auto trans. If I don't like the fenderless drive, I will probably add some rear trailer fenders, and try some cycle style fenders that will turn with the front wheels.
In process build pictures, I need to update the pictures. Gene
