Wondering if anyone has had any problems using stock port Indy EZ heads with 67 440HP exhaust manifolds, or other year HP manifolds for that matter. I did a mock up and looks like number 6 and 8 might be tight to fit a plug wire on because of the angle plugs. My concern is getting wires to work with this set up. Thanks.
RS23L7 4-Speed
