I still have a few parts to round up for the swap but I'm getting closer. I've been using a factory '68 B body Dana 60 under my Coronet for the past 30 years. It has worked just fine but I figured it was time to step up to the newer stuff so I got together with DoctorDiff to order a new combo.
This one is narrowed just a small amount, has the billet pinion yoke, 3.23 gears, helical differential, Baer rotors and the Mustang calipers. I need to bend up the brake lines yet and then figure out the e brake setup. Hopefully everything else lines up properly so I can drop it back on the ground.
