Originally Posted By fast68plymouth
Chinese dampers(or rockers).......... not on anything I build.
Not a good place to scrimp.
Glad you made the switch and found it to be worthwhile.
Both of those are going to be hanging on the wall in my garage as a reminder to NOT by cheap junk!!!! I cant believe how much smoother the car is at ALL RPM's, it is amazing. now if the weather would get cooler I will go to the track & try to crack into the 10's
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
