Thanks for the replies fella’s!
So, I should maybe have mentioned but the W2’s are currently set up for solid roller. I have a set of new 20 year old Herbert solid roller lifters.
So if a guy was gonna go with the w2’s, tunnel ram and the 8” convertor...bearing in mind it’s 4400lbs, what would you guys suggest for a cam?
I will be driving this thing as far at 60 Miles one way the odd time.
