I have taken my stock front hubs to my machinist,ran in on cad said there is no way to convert bolt circle,unless you plug weld holes and redrill(not happening on cast hub liabity issues).He suggested mustang 2 spindles and probably having to ream holes (tapered)where ball joints go thru.Checked with moser said they plug welded and drill but no more and i know i have seen 5 lug wheels on front of dakotas in stock/superstock,but i might go to boneyard and get measurement off crown vic spindle stud. I know for sure dakota spindle stud is bigger than ford.Rearend is a 9 1/4 out of durango with shock mounts moved. Don
