Not sure what you are looking for but I stuck the biggest Summit cam for a small block in my 360. Runs very good but does not sound like it has a cam in it. Real smooth with 14* initial and 35* total on the mechanical.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
