are you sure it is dexcool or the chrysler antifreeze cause the color looks the same. (chrysler engineers must have seen the same things i am talking about) i took an engine class through chrysler bout 2 years ago and they stressed not to use dexcool cause they are not the same. gm has been using it since 96 and i have seen a lot of problems. chrysler has used hoat since about 00 or 01 and i have not seen any issues that i would atribute to antifreeze. take apart a gm with the same amount of time and miles and put a chrysler beside it and you will see the difference. we still put dexcool in gm and hoat in mopar but dexcool is job security for me at the dealer.
