Originally Posted By dvw
I made tabs so the cable runs along the upper RH 1/4 panel. Glued the tabs on with Plexus to the trunk gutter. Then over the tub and along the right door sill under the carpet. It terminates at a firewall pass thru near the gas pedal. That way you don't see it laying in the trunk.
Doug
Doug, how did you do the lever/handle for the battery cutoff switch, inside the car?
Jeff
69 GTX 68 Road Runner
