So how much oil is your engine using? I would love to know. My setup is very similar, (bore/stroke) I use a factory PVC and an open breather on the opposite valve cover. I have ZERO blow by even with the 4.5" crank. But, with clean plugs, no leakes, I use a quart in 250 miles. What about you?
