I transported my done Dart body 55 miles in an enclosed trailer with the typical 3/4" floor and the right front caster fell through the floor and messed up the fender! Make sure if you do use a caster setup like shown above put a couple of decent sized plywood sheets underneath them. I have done it again with several other cars with no issues, just tie the two casters together across the front and cross tie the straps.
JB Rhinehart, Realist
A-Body's RULE!
