check with a test light at the sensor and bulkhead and the gauge. you can start with the gauge and work your way forward to find the break.
it should blink.
My plan is to remove the radio to get to the main cluster connector then check continuity from the dash to the sensor. If that's good there is a problem in the circuit board. If not, then I'll check continuity from the bulkhead to the to the dash.
