Well, after a few runs with the new motor the trans started sliding on the 2-3 shift. I made it to the finals Sat nite (finished runner up) but the motor flared on the 2-3 shift. Since putting the new motor in it the 2-3 shift has been a bit soft.
Anyway, now I gotta build a trans. I'm running a 470 w/stealth heads and turning 6.06 on a 600' track.(about 10.20 in the full 1/4)2800# Dakota
I have a spare 727 out of a motorhome that should have the 5 disk clutch in it. Should I put a 727 together with a few good parts or go with a glide, witch means modifiy cross member, new drive shaft, adapter kit, shifter, converter?
P.S. I had a 1.341 60ft Sat nite so its leaving hard for my et.
