Nobody knows? There are two pipes sticking straight up behind the supercharger that go to the heater core. Not like other engines that have a hose to the block and another to the water pump. The reason I need to know is I am using a Vintage Air unit and it has a heater control valve that has to have coolant flowing in a certain direction to work.
