Can you imagine a G/Gas car that weighs 3570 Lbs. + the driver weight with a 3.09 1st gear and a 7.17 ratio Dana 70 in the rear with that weight flywheel
I have seen that car raced in the mid 1970s, the driver was very busy shifting (at 8600 RPM) the first 300 Ft.
I drove a old 1970 Duster Pro bracket car back then (mid 1970s)that had a 30 Lb. flywheel with the 3.09 first gear ratio and a 5.57 rear gear ratio and Dana 60 out of that same G/Gas car shifting it at or near 7000 RPM with semi stock 340 motor with 13x30x15 inch slicks, I was real busy the first 300 feet also
