IMO, the problem with 17"-18" etc is the short sidewall... intended for better cornering/steering/handling response. Cars with monster BB engines -- especially a heavy Hemi -- need more sidewall to carry the weight, as well as through the corners. Short sidewall tires are not forgiving to the weight demands of a front-end heavy BB car.
You could consider a 16" and run 255-50-16 tires an minimum 8" rims.
The 17x8 or 17x9 YearOne replica Mopar rims do look pretty good. You could run 275-40-17 up front (preferably on the 9" rim), as well as a 305 or 315 on the rear ( a little pinched but will fir.. I've seen it). the YearOne rims have the correct backspacing to fit front and rear... I suggest staying with their 9" rims front and rear.
As everyone knows, the choices of 15" are so limited. I run BFG T/A 255-60-15 front, 275-60-15 rear, both on 15x8 vintage minilite road race rims... these are my cruising tires... rides/handles just fine.
I also run BFG Comp 255-50-16 on vintage minilite road race rims, 16x8 front and rear... for track lapping events... handles fine.
Eventually, I'll be getting 18x10 (or 10.5-11 wide) rims and run 275-35-18 200 compound tires for track events.
Unless you're running track events, the choices of 15" tires are OK for cruising... even at 245-60-15 fronts as the smallest you'd want to go.
Mopar Mitch "Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers! Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
