it just takes a little practice.as said you tube is your freind.if you want ANY spray gun to last, clean up is VERY important,do it as soon as your done.
, you can't hurt an expensive by learning with it, unless you do not clean it well. I think a better question here, is an expensive gun worth the cost for its benefits, others have already touched on that. Eventually owning two price range of guns makes sense.
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
