Building this for a 68 Charger that will be backed up by a SST 5 speed manual and a Dana 60 4:11
After having the machine work completed, I will be running stock steel crank, stock rods, forged flat tops with reliefs at .030, zero deck, Close to 10.5:1
440source stealth heads, with Comp Cams 10 degree locks, Comp Cams Dual Valve Springs, with factory rockers Comp Hydraulic Flat Tappet, Advertised Duration 275/287, Lift .525/.525 and double roller timing chain/gear and high volume oil pump
SO, with the above I need advise for street application oil pan and pickup tube, would like a factory style 7qt ??
Also need advice on street intake, carb, headers, and ignition
THANKS FOR YOUR HELP!!!!
