No, I didn't. I checked everything with the exception of pulling the cluster out. Switch works, fuse is good, all bulbs are good, manually grounded the gauge cluster and switch. Nothing. I did notice that the light on the gear indicator on the column doesn't work either. Since it and the radio light don't work and they are not actually part of the gauge cluster lighting I don't know what else to look for.
