Not sure on that carb, but on my Holley HP, the hole for the air filter stud goes through the carb and will have a vacuum leak if no stud (or bolt) is installed.
Being a used carb, check the sizes of the air bleeds, idle restrictions, power valve restriction, jets, and emulsion holes and see if they have been changed from the stock specs.
