Originally Posted By dvw
I never set mine hot. With aluminum heads set the int .006"/ exh .005" tighter cold than the hot spec. Warm it up and measure a few intakes and exhausts. Recheck those same valves after it sets overnight. How far did they change from the measured hot setting to the current measurement? Then do the math of the change. Now when you set them cold they'll be where you want hot.
Doug
This works for me. Also agree, a little loose on break in will not hurt.
