A little more involved but, crack ableeder loose and see if the brakes release. If so it's a hydraulic problem.
Get it to do it again, crack the rear line loose at the master. Do brakes release? If so problem it s master or booster related. If not then hose, line or p valve related. Duplicate symptoms and crack line at various places, note the results.
Angry white pureblood male
