Spent alittle time in the garage today, did anyone notice I didn't put the heads on right? I had just set them on real quick, not bolted on, just held on by the pins. Went to bolt them on today before something happend, and saw they weren't all the way on. Now the engine width including the valve covers fit inside the recess, but I will still need to cut more out. Cut the bottom of the stock steering column, cut a hole in the firewall, it comes real close to where the exhaust manifolds would be. Will find out tommorrow.
