At the moment leaning towards the scat rotating kit P/N: 1-48033BI. Should be right around 11.6ish to 1 or so depending on how thick of a head gasket we end up putting on it. I think the rods would be the weakest link, but with the lower rpm and still not a ton of compression they should handle the job okay. A plus with the I beams is they should only require minimal or maybe no clearancing.
