I use a #12 Peterson breather. They are really well built and screw right into the valve cover. If the Peterson breather doesn't work then you can hook up a remote breather tank. I've done the remote tank before and it works really well for big race engines. Mount the remote tank up by the radiator and run a #12 line from the valve cover.
