Next time you've got a problem like that; the shop I work out could probably get you sorted out. We have all the line testing equipment at the shop and we've upgraded to XRP's latest hose, the Pro Plus Race hose. Expensive stuff, but with the crimp fittings and PTFE liner; it's rated for modern fluids and much less time consuming to assemble.
https://www.xrp.com/xrp-proplus-race-hose/but if you ever find yourself in a jam, we're in San Carlos. Shop is Performance Fabrication.
