Originally Posted By charge70
MegaParts has them.You will need to remove the release rod to install.
I did see it on Mega Parts. It looks like it comes with a rubber grommet and 2 springs. Is the rubber grommet right for 69? For some reason I thought the part was made of plastic or nylon. Not that I am an originality snob. I'm not. The car is a driver.
If it is a common rubber grommet I may just be able to pick one up locally.
Scott
1969 Super Bee, 383/4 speed
