Went down to the hardware store, came back out , turned the key, nothing. got dash gauges,dings when the key is on , lights. Turning the key to start nothing changes, no dimming, no clicks. Got it towed home. Figured it was the ignition switch , changed out the electrical unit. Nothing changed. Good batteries , clean and tight cables, could the starter just stop working????? but there is no draw on the system when the key is turned to start. Where to look next?
it's ok to butt heads, just don't do it with a butthead
